06-17-2014 07:46 AM
Hi All,
how to build the lookup string for get the "LowSpec" from the "additionalResult";I use "Locals.ResultList[1].AdditionalResult[0].Parameters[0].LowSpec" can't the target info and return an property name error.
06-17-2014 09:35 AM
Try something like the attached image. I think you will have better luck.
06-18-2014 05:18 AM
Thanks,I can get the "LowSpec" value by you method!but I get the "MeasValue" that is an numeric array,it's no error but return empty array,I use TestStand 2010 and LV 2010;
06-18-2014 08:19 AM
I'm surprised that doesn't work. If you probe the variant wire does it contain any information? It should.
You may have to get your MeasValue array as a property object and then iterate through it's subproperty 1 by 1 unfortunately.
