01-04-2006 09:29 AM
In my specific sequence file I added the Callbacks: SequenceFileLoad, SequenceFileUnload, PreUUT. In addition to that, my MainSequence is calling 2 subsequences.
I put the propertyLoader step (setting few values of the SequenceFileGlobals) in the setup section of the SequenceFileLoad, checked the 'Use Current Sequence File' and selected ALL SEQUENCES tag in the 'Sequence' option. I verified that it does what I wanted. Then, is it entered the PreUUT subsequnce, the values returned to the "original" values.
Is that a bug?
If not, how do I use the PropertyLoader in a sequenceFile that include several subsequences as well as Callback sequences.
Rafi
01-04-2006 11:27 AM
Rafi,
I am assuming you are using TestStand 3.1 or higher.
I am not sure if I understand your problem.
Are the subsequences in the same sequence file?
Could you reproduce the behavior in a simple sequence file and attach it to your post?
Best Regards.
01-04-2006 12:42 PM
I forgot to mention....it is TS 3.5.
As per your questions-- yes they all in the same sequence file.
mySeqFile.seq
SequenceFileLoad
01-04-2006 12:42 PM
mySeqFile.seq
SequenceFileLoad
SdequnceFileUnload
01-04-2006 12:42 PM
mySeqFile.seq
SequenceFileLoad
SdequnceFileUnload
01-04-2006 01:00 PM
mySeqFile.seq
SequenceFileLoad
SdequnceFileUnload
PreUUT
Seq1
Seq2
AS I said....I put the property loader in the setup of the SequenceFileLoad, I see that it works properly in that subsequence. Then, after the SuequenceFileLoad is finished, I do Ctl+F5 for Test UUT's. I put a breakpoint in the first step of the preUUT subsequence and check the context. I notice that the variables in the FileGlobals to whom the property loader writes, have been changed back to the original values.
I'll try to create a simple program to duplicate it but it may take me time as this test station is very busy.
Rafi
01-05-2006 12:19 PM
