I'm trying to dynamically create a sequence file through Labview with the help of the API. So far I have eben able to create the file, add a sequence call into the file as well as link the sequence call to a particular sequence file that will be called. Now, I wish to add certain "non-adapter" steps into the sequence file like Goto, Label, Property Loader etc. I can't seem to find a way to access the propeties once the step has been added. In the LV adapter, I was able to access the TSAdp.SequenceCall API and manipulate the properties. How do I do the same for the non-adapter ones?
Also, when I load the sequence file through the TSAdp.SequenceCall API, i'm unable to access the parameters and link the inputs and outputs. I've attached a portion of my code and would really appreciate some help.
Thanks in advance,
-Anshul
