03-01-2016 04:43 AM
i am using NI switchexec in TS2015.
When i rightclick a switching step and select RunSelectedSteps then the configured switching is executed.
But when i click another switching step and execute it then it looks like as if switchexec executes an "Open all" command.
Is there an option to keep the previous switches closed?
For debugging a testplan i need to execute teststeps in different sequnces.
10-17-2016 04:24 AM
One of the possibilties why this is happening is this :
Probably in your setup there is a an open all step.
Whenever you execute any step automatically setup is run first as shown below.
Run setup
Run Your selected sequence.
Run Cleanup.
Do check if this is the issue?
Ravi Shrigiri
