12-13-2006 03:34 PM
12-14-2006 01:05 AM
Hi 2and4,
Answer to Q1: Its a property of the Step or Result, depends where you are referencing from. If you are unsure then quote the lookup string eg "Step.Result.PassFail".
Answer to Q2: You are probably referring to the Parameters which belongs to the active sequence you have displayed in the sequence editor. Its empty because you have no Parameters defined in the sequence. Try this, in your active sequence, select the Parameters tab. Insert a Parameter, it doesn't matter what it is. Now view the Sequence Context by the Expression Browser. You should now is a + sign next to Parameter. Expand this and you will see you Parameter you inserted.
Answer to Q3: Yes, the actual result or status is in Step.Result.Status which is a String. This can be "Passed", "Failed", "Error", "Done"
Answer to Q4: If you look at the Status Expression for the PassFail step, you will see it has a different expression. The PassFail doesn't do any limit checking. If Step.Result.PassFail is True then the step passes and if False it fails. It's that simple.
I hope this helps.
Regards
Ray Farmer
