04-19-2013 02:17 PM
Dear Support,
I have two questions regarding the parallel sequence model:
I am trying to find a global variable or any variable that can be universally read from any thread / step . For instance:
- Parallel sequence Model
- 2 UUTs
- The main sequence has 20 steps
- I am looking for a variable that can be read universally across both UUTs in any step. I have tried many, even the station global variable - as a Boolean - for "Abort" . But that did not work either.
Question TWO: How can I bring out this universal variable to the UI ? Can you point me to an example? Do I use the "Lookup" ,. I could not get that to work. Can I use the "Label" ? I could not get that to work neither.
Thanks! Brad
04-20-2013 11:37 AM
04-22-2013 03:41 AM
The station global should have worked since you are just reading a variable.
In case you are also updating the variable value you will need to save it also immediately after you modify.
(Engine.CommitGlobalsToDisk ( promptOnSaveConflicts = True)
