04-04-2013 11:58 AM
I have two boards that are tested as a pair and I would like to have the log name show both serial numbers for tracking purposes. The logfile name is currently set up to show the serial number of the mainboard. I put the second serial number into a StationGlobal after it is scanned it in. How can I add the second serial number to the logfile name?
Tracey
04-05-2013 05:49 PM
Hi vocollect,
I have found a Community Example that demonstrates how to modify the report name in Report Options. The pictures may not show exactly what you see If you are using TestStand 2012, but the steps are essentially the same. I hope this helps!
How to Add User Information to a Report Name: https://decibel.ni.com/content/docs/DOC-21744
Jason D
Applications Engineer
