Hi Caribe,
I dont know why that's open like that, but it doesn't seem to be hurting anyone and when you close the configure VI dialog, it goes away.
You will also notice that it is present when you use the Specify Module option and select Configure VI, only you dont notice so much because the main configure dialog is sitting on top of it. If you drag the Configure Dialog down the screen you will find it.
Maybe the LabVIEW guys will hide on later releases.
What LabVIEW are you using?
Regards
Ray Farmer
Regards
Ray Farmer
