NI TestStand
How do I programmetically determine whether the sequence is running in TS Runtime engine or Development version ?
You can check if your are running in the SeqEditor by checking a RunState property.
I think its called RunState.IsEditor, its a boolean. Its True if in the SeqEditor.
Check the Programmer Reference Help, there is a breakdown of the Sequence Context.
Ray Farmer
Ray Farmer
(2,793 Views)
Thanks Ray, It worked perfect.
(2,782 Views)
