NI Home
Cart Cart | Help
You are here:
Reply
djdewitt
How do I process user command line arguments inside of the Sequence Editor?
Using TestStand 4.0, how would I go about storing "extra" command line arguments processed from the /runentrypoint command in the Sequence Editor specifically?
Trusted Enthusiast
RayFarmer
Re: How do I process user command line arguments inside of the Sequence Editor?
You can't, your stuck with whats defined in the Reference Manual.
Regards
Ray Farmer
Regards
Ray Farmer
djdewitt
Does TestStand 4.2 address this feature?
Scott_Richardson
djdewitt -
TestStand 4.2 does not have this feature; however, we do have an internal issue (#163169) to track this request. You can actually get the commandline passed to the TestStand Sequence Editor using the below psuedo code in a sequence; however, currently the TestStand Sequence Editor displays a prompt when it does not recognize a custom token on the command-line and there is no way to suppress this.
Locals.AppMgrRef = RunState.Engine.GetInternalOption(InternalOption_ApplicationManager);
Locals.CommandsRef = Locals.AppMgrRef.CommandLineArguments;
Locals.CountNum = Locals.CommandRef.Count;
For i=0 to Locals.CountNum - 1
    Locals.CommandString = Locals.CommandRef.Item(i);
End
One suggestion is to use a batch file to write the commands to a dedicated text file and then launch the sequence editor. You can then use a sequence in the sequence editor to read from the file.
Lastly, I just tried something and I do not necessarily recommend this, but I noticed that the Sequence Editor does not prompt when using the /goto token, so if I use the below command-line, it seems that no prompt appears, the goto command does nothing, and the psuedo code accesses the command-line tokens:
"C:\PathToApp\SeqEdit.exe" /goto "location tokens that do nothing" /run MainSequence "C:\PathToSequenceFile\GetCommandLineArgs.seq"
Keep in mind that NI does not necessarily support this but it does seem to work for now.
Scott Richardson
djdewitt
I just went ahead and did exactly as you suggested before I even had a chance to read your response and made a batch file that wrote the arguments to a text file which is parsed via a sequence callback in my process model. Your other solution seems pretty interesting though.
Trusted Enthusiast
RayFarmer
Another way might be to develope the Operator Interface which you can launch in editor mode. You should beable to add you own parsing for the command line.
Regards
Ray Farmer
Regards
Ray Farmer
