NI TestStand
How do I make a local variable of type NI_LimitMeasurement?
I am writing a custom sequence to be called in a process model that produces a custom report format. In this sequence, I would like to create a local variable of type NI_LimitMeasurement which is a standard type in NI_Types.ini
When I am in locals tab and right click to add a local variable this type is not listed in the insert local menu. How can I get it listed there so I can create a local of this type?
Lori
(3,011 Views)
Lori,
What version of TestStand are you using?
You should be able to add a 'NI_LimitMeasurement' local variable by going to Insert Local->Types->NI_LimitMeasurement.
Hope this helps.
Antonio Lie.
(2,997 Views)
It's a hidden type, so you have to go to the Configure | Station Options and select Preferences Tab on the Station Options Dialog.
Then check the Show Hidden Properties check-box.
Then you will beable to do Insert Local->Types->NI_LimitMeasurement.
Ray Farmer
Ray Farmer
(2,988 Views)
Thanks Ray, that did it! I figured it was something real simple like that......
Lori
(2,980 Views)
