Wendell,
We provide a Test Data Enterprise Management Appliance, called IntraStage (
www.intrastage.com) it is designed to offer a low IT resistance path solution. We provide an appliance (physical box) which you plug into your network. You then point to theTestStand databases using a Wizard Interface, and you are then ready to report through internet explorer without any additional software licences.
Enough of the sales your individual questions are addressed below:
Q. We're currently running approximately 100 test stations, each station will have an instance of TestStand running. Any data loss is unacceptable.
A. The product was designed to suck data from the TestStand Databases when the network is up, network down time has no effect on the data, as SQL transactions ensure the data is only removed from the rigs when the data has been copied to the central storage area.
Q. Ideally we would like to log test data from each station to a centralized database.
A. Thats what we envision our product being used for, and then backup procedures are included at the server location.
Q. The problem: this is a high volume 3 shift a day environment and the network is never operational 100% of the time. How do I log locally to avoid data loss but migrate test data to the centralized Oracle database in the background during those times the network is operational? What are other TestStand users doing to guard against data loss during network outages?
A. As a generic answer you have to do exactly what has been described above. Log locally on each sttion, but have a central server "applaince" pull the data from the rigs.
Good Luck if yu rquire any further information or a demo on IntraStage, please give me a call Andy Long (858) 342 6795
