09-07-2006 11:38 AM
09-08-2006 09:17 AM
09-13-2006 09:22 AM
09-13-2006 09:41 AM
Howdy Dillon,
It appears you are on the right track but I do have one suggestion after
browsing through you VI. It’s not the best practice to use Application Manager Control simply in your code
modules. The Application Manager Control was
designed to be used in Operator Interfaces. To access the Engine, you could either instantiate the Engine
directly in LabVIEW, or pass in the SequenceContext into a LabVIEW
VI and access the Engine that way. See the attached screenshots.
There is also a good KnowledgeBase entitled Getting
a List of TestStand Variable Names (i.e. Locals, Parameters, FileGlobals,
StationGlobals) Pr... that is very helpful.
Good luck.
Best Regards,
09-13-2006 05:40 PM
