10-01-2004 12:33 PM
10-01-2004 03:38 PM
04-16-2007 05:30 AM - edited 04-16-2007 05:30 AM
Hi Mike,
A really late reply so maybe you solved your problem already, but I wanted to write for the sake of completeness.
If you write
RunState.Step.TS.NoResult = (Step.Result.PassFail) ? True:False
as a post-expression for the step you want to delete the result (not as a separate step) then for that step no result is displayed in the log file if the step passes.
Message Edited by ebalci on 04-16-2007 01:34 PM
Message Edited by ebalci on 04-16-2007 01:38 PM
