10-12-2006 10:48 PM
10-13-2006 12:34 AM
Where abouts are you setting the "FileGlobals.BuildStatus". If you are doing it in the Setup of MainSequence then it would be to late as the LogToDatabase callback sequence would have already been run.
Do you Override the LogToDatabase sequence in you sequencefile?
Regards
Ray Farmer
10-13-2006 01:03 AM
I set the "FileGlobals.BuildStatus" in the PreUUTLoop seq callback in Client seq file, please see attached file.
Thanks!
Jacky
10-13-2006 02:03 AM
10-13-2006 02:10 AM
10-13-2006 02:20 AM
I changed my way, below is the process step by step:
1, configure client seq file
Insert PreUUTLoop, in this seq callback, insert a step used to change "StationGlobals.BuildStatus"
2, Configure Station Globals
Add string variable of "StationGlobals.BuildStatus"
3, Configure process Model
In Test UUT Entry point:add a local string of Temp_J; insert a step to have "Locals.Temp_J=StationGlobals.BuildStatus";
In the "log to data seq" callback, insert string parameter of Temp_J
Open "log to data seq" seq and insert string parameter of Temp_J
4, Configure Teststand database option
In the columns/Parameters tab, add new filed of BuildStatus,with the expression of "Logging.Temp_J"
5, In UUT_Result of SQL sever,add a new filed of BuildStatus
6, Save and Run
Thanks!
Jacky
