NI TestStand
How can i create a testreport in a separte file after every subsequence?
The problem we have is as follows:
We want to make a systemtest on our product. If we run the complete test the reportfile is too big. Is there a possibility to create a reportfile with his own name automaticly after every subssequence. We want don´t want to run everz subsequence in single steps because it should run over the weekend.
(2,472 Views)
This is a question that is related to the one that I posted here.  I went with the XML expanded style sheet, but an HTML solution may be a better bet if someone comes up with a good one.  So, if you come up with a good answer, I would love to know about it as well.
Bob Young
(2,468 Views)
