09-01-2005 01:30 PM
09-02-2005 04:03 PM
Hello Guy04,
I think what you want to do in this case is add a step to check the availability of a route before choosing the route. This can be done with a switch command such as niSwitch_CanConnect. Then based on what this function returns, you could select a route in switch executive. So it would be analogous to a case structure in LabVIEW (if you're a LabVIEW programmer). I hope this helps you out. Have a good one!
Tyler S
09-04-2005 02:06 PM
09-06-2005 12:53 PM
