I use a changed CVI Operator Interface (TestStand 3.1) and I will open a sequence file directly and NOT via 'File -> Open Sequence file...'.
The reason is, I have a lot of sequences in the same directory and I prepared an extra menu item to select a sequence file in a UUT related tree. After I have selected the sequence file I will open this sequence file but I d'ont how to do it.
