NI TestStand
How can I make step variables persistant?
I have a step that has a variable, "voltage" and I can read and write to the step by refering to "Step.Voltage" (assuming I'm in the step). But if I write to the step, it's only persistant to the rest of the sequence. Once the sequence is over, the data reverts. I understand that this is because calls to runtime copy of "step.voltage".  I've tried playing with options such as editing the property flags to enable "shared" or "shared at runtime" and that worked great except that it edited all instances of the step. I've also considered trying to edit:
RunState.SequenceFile.Data.Seq["MainSequence"].Main["VOLTAGE STEP"].Voltage
but I want the reference to be relative, not absolute so that any copies "Voltage Step", no matter what they are named, how many instances there are of the step, what sequence the step is, it always refers to the edit-time copy of itself.
CLED (2016)
(2,789 Views)
InfiniteNothing,
You can use an expression similar to the following:
RunState.StepGroup == "Setup" ? (RunState.SequenceFile.Data.Seq[NameOf(RunState.Sequence)].Setup[NameOf(RunState.Step)].Voltage = 41) : (RunState.StepGroup == "Main" ? (RunState.SequenceFile.Data.Seq[NameOf(RunState.Sequence)].Main[NameOf(RunState.Step)].Voltage = 41) : (RunState.SequenceFile.Data.Seq[NameOf(RunState.Sequence)].Cleanup[NameOf(RunState.Step)].Voltage = 41))
In this expression I am setting the Voltage property of the current step to 41.
Notice that in order to obtain the current sequence name I use NameOf(RunState.Sequence), also notice that in order to obtain the step name I use NameOf(RunState.Step).
I had to use conditional operator to select the expression to evaluate based on the current Step Group.
Hope it helps
Antonio Lie.
(2,775 Views)
Wow. Thanks man. That looks like it'll work. I was thinking along those lines but thought I'd ask before I dove in.
CLED (2016)
(2,763 Views)
