05-10-2007 03:47 PM
05-11-2007 02:52 PM
TestStand uses relative paths, so it never actually stores the full path to the VI unless you specify an absolute path.
If you would like to find the full path of where it has been found, you can use the method Engine.FindFile or the expression function FindFile to find where TestStand is locating this file.
Matt M
NI
05-11-2007 03:46 PM
