04-09-2015 06:32 PM
Tools >> Import/Export Properties looks promising but I never get the acual expression no matter what I select.
04-09-2015 11:22 PM
You can search within TestStand. Why do you need ot export them?
Go to Edit>>Find/Replace In Files... Then you can set up the filter however you'd like.
04-10-2015 12:20 AM
Good point, but I want to write software that parses a file with ALL the expression. And I just figured out how to do it; you can save the file as XML. That's not where it should logically be, in the File >> Save As... place, but a sequence file properties dialog box that I don't have the exact name right in front of me.
04-11-2015 01:24 PM
You can also go to Tools>>Sequence File Documentation. This will print to either text or html. This way you don't have to change the format of your file as you described.
Hope this helps,
04-14-2015 12:42 PM
This Tools>>Sequence File Documentation is certainly much faster and I'm glad I learned about it; but it doesn't capture the information I want which is the contents of expressions in a Numeric Limit Test.
Exporting the sequence file as XML gets absolutely everything including those expressions.
