07-05-2005 08:39 AM
07-06-2005 03:55 AM
Hello Bastian,
two ways I know to achieve this aim.
First way:
Add the Sequence File Callback "ReportOptions" to your Sequence File (via Menue "Edit"). Then force in Sequence "ReportOptions" the Parameter "DisableReportGeneration" on Value True (e.g. via Statement Step or Dialog Box Step). Now TestStand generates no report. The disabling happens one times before SequenceFile achieves UUT Loop.
Second way:
Add the Sequence File Callback "SequenceFilePostResultListEntry" to your Sequence File (via Menue "Edit"). Then force in Sequence "SequenceFilePostResultListEntry" the Parameter "DiscardResult" on Value True (e.g. via Statement Step by mapping from a FileGlobal). TestStand will generate a report but no StepResult contained in it. The disabling happens everytime in UUT Loop after every step runs.
I hope this helps.
Christian
07-07-2005 02:14 AM
07-07-2005 03:18 AM - edited 07-07-2005 03:18 AM
Message Edited by Sean on 07-07-2005 09:19 AM
07-07-2005 03:38 AM
I've tried this now. It took me about a minute to do, after I'd worked it out. Step by step:
Configure >> Station Options >> Preferences Tab
Tick "Show Hidden Properties"
Open your sequence.
Edit >> Find...
Type "NoResult" into the "Find:" control.
Tick "Limit Search to:" and select either your sequence or all sequences.
Click OK.
In the results window, click the top result.
Press Shift, and click the bottom one. All should be selected.
In "Replace With", type "True".
Click "Replace Value".
Now manually switch on the ones that do need to be reported.
07-07-2005 06:49 AM
