What I'd like to end up with is a Custom step that
1. Takes several string parameters
2. Makes several calls to functions in a DLL
3. Returns and stores error codes returned from the function
I've been through the KB article "How Do I Make a Custom Step Type".
This got me about halfway there; while helpful, it didn't provide a
reference for some of the questions I had, specifically:
1. What sort of sequence action type should I start with (to use as a template)?
2. If I start with a "Call Executable", do I need to specify the module when I incorporate the step into the sequence?
3. How does one pass parameters in and out of a custom step type?
4. How does the step type report progress/errors to the report?
Thanks in advance.
Mike
