03-09-2006 09:19 AM - edited 03-09-2006 09:19 AM
Message Edited by SercoSteve on 03-09-2006 09:22 AM
03-09-2006 12:05 PM
03-10-2006 01:54 AM
03-10-2006 06:45 AM
03-13-2006 02:01 AM
Hi Jon,
Thanks for your post, I had completely missed that you can create a property node of a UI Control. Unfortunately my original post still stands. When the TS engine is initialising the UI controls are shown in there design state even if there Visible property has been permanently set to FALSE. As soon as LabView gets control I can set the Visible state successfully, but I get a period of about 2 seconds when TestStand has control making the resultant UI initialisation look less than professional. I am yet to check if this is just a development thing, or whether I will see the same sort of display in the run time environment.
Any ideas?
Steve
03-13-2006 03:36 AM - edited 03-13-2006 03:36 AM
Message Edited by JonBowers on 03-13-2006 03:37 AM
03-13-2006 03:59 AM
03-13-2006 05:19 AM
03-13-2006 05:23 AM
Hi Jon
Yeah that's it. We are running on a slow (ish) PXI rack and even see it in the run time environment.
Steve
03-13-2006 09:15 AM
