Thanks for the reply.
I do know how to convert from DD inside labview. But I'm using the Express VI option and directly accessing the DAQ assistant from TS so I never see LV. After configuring the Express VI using the assistant, you have to choose a destination for "data" in the "specify module" window. I guess I could just create a VI and do the conversions in LV but it seemed cleaner to use the Express VI directly from TS. But using this requires breaking data out of the DD type "within" TS.
I made an example of the problem using the "Simulate Signal Express VI" simulating a DC signal with noise. Can the LIMITS be set to ensure noise levels do not exceed some threshold?
Thanks again,
Adam
