03-13-2006 11:04 AM
03-13-2006 01:45 PM
Sivasn,
Every time you reinstall TestStand the language files under '<TestStand>\Components\NI\Language\' are replaced.
If you want to preserve your changes make a copy of the file you want to modify and save it under '<TestStand>\Components\User\NI\Language\'.
The files under the 'User' directory wont be replaced next time you upgrade TestStand.
You do not have to copy "modelstrings.ini" and "UIStrings.ini"; you could add the required strings to '<TestStand>\Components\User\NI\Language\English\CustomStrings.ini' as an alternative option.
Hope it Helps.
If you have any question let me know.\
Antonio Lie.
03-13-2006 02:38 PM
