I've read the examples about error handling and created an example that allows me to handle errors.
What I'm not sure of and have not found any discussion about is:
How do I turn it back over to TS to handle errors I am not specifically interested in?
The attached example (if I understand correctly) makes my error handler THE error handler. It uses the same dialog the TS examples show that is similar to the TS default error handling dialog. I would like to handle particular errors (as the example shows) and then leave the rest to TS's normal error handling.
Mac
