Hello
I want to make a HTML report per day, including all the executions run of this given day. I found out that in TS 3.1 there is an option (Configure> Report Options> Contents> Append if file already exists) but it does not sem to work. What actually happens is that a series of reports is generated with the same base name plus a number (i.e. Report.html, Report_000002.html and so on).
Is there a way to append these HTML reports?
