I have created an html report in TS. My report has a graph in it that will display correctly when viewed from within Teststand. However, if I try to view the report from Internet Explorer, the graph is not displayed unless I'm on a computer that has Teststand installed. I found a similar problem here on the boards where the user was creating xml reports. I tried using the fix specified for that problem but still did not correct it for html reports. Is there a similar fix for this?
