Hmmm.....
This works correctly but my top-level sequence uses mutiple For-Each loops (we're doing sweep tests), so using the
ResultList approach will require some unwieldy mechanism to scan for my sub-sequence PassFail
Status and check for the appropriate
StepName.
Is it possible to reference the
StepName to get the step result
Status in a NewExecution sub-sequence?
Why am I doing all this? I'm looking to record yield information based
on the PassFail criteria in two NewExecutions controlled by a top-level
sequence. Both steps in the NewExecution sub-sequences must pass, to
generate an overall test pass during my sweep.
Chroma
