11-19-2006 06:40 AM
11-20-2006 10:40 AM
11-20-2006 11:03 AM
11-20-2006 01:57 PM
11-21-2006 07:45 AM
11-21-2006 08:28 AM - edited 11-21-2006 08:28 AM
RunState.Report.Location is a string therefore all you need to do is use
char *ReportLocation = NULL;
TS_PropertyGetValString(testData->seqContextCVI, &ErrorInfo,"RunState.Report.Location",0, ReportLocation)
Regards
Ray Farmer
Message Edited by Ray Farmer on 11-21-2006 02:28 PM
11-21-2006 08:52 AM
11-21-2006 09:04 AM
Put a breakpoint on the step that calls your function then have a browse of the context in the SeqEditor to see what the runtime value is.
Regards
Ray Farmer
11-21-2006 10:06 AM
11-21-2006 12:40 PM
Hi Moshik,
There is a ReportFilePath variable stored in the ProcessModel under the Locals. However, if you want to access this from your sequence file, it is accessible from RunState.Caller.Locals.ReportFilePath.
You should be able to use the same method described above to get to this variable in CVI.
Matt M.
NI
