04-17-2013 09:27 PM
Can anyone help to explain the following error message? I was trying to get values from SQL database using Data Operation step (Database).
Jane
Solved! Go to Solution.
04-18-2013 12:13 AM
Just add some more information on my question:
when I set the SQL Statement as "SELECT module.module_id, module.module_name, module.batch_id FROM module WHERE " + "module_name ='1308405199'", there is no error.But When changed the SQL Statement to "SELECT module.module_id, module.module_name, module.batch_id FROM module WHERE " + "module_name ='+Locals.module_name+'", then the errors message came up. The Where Clause seems only accept constant value. Why? Did I input something wrong?
Jane
04-18-2013 08:56 AM
The TestStand property token must be outside the quotes. I believe this is what you want:
"SELECT module.module_id, module.module_name, module.batch_id FROM module WHERE module_name='" + Locals.module_name + "'"
