NI TestStand
Get Type of Step by activex
Hi guys,
I want to get the Type of the Step by activex. I have the name but in case of a Statement Step the name can be changed.
If I get the Field Type that we can found on the tab Properties, General I will be able to get information I want following the Step Type.
Thanks in advance.
(4,400 Views)
You can use Step.StepType.Name to get the type of step.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,395 Views)
No, I don't want to use the Name. In case  for example of a statement Step the name can be changed.
I'm creating a sequence that generate a documentation from a sequence file. Following the type of the Step I will get more or less information from it.
(4,377 Views)
The solution given is correct and working.
Its the name of the "step type" not step.
For a statement step type it will always return "statement" irrespective of the name of the added step.
(4,370 Views)
Oh pfhenry21.  I am hurt that you wouldn't trust my solution... however, I completely understand.  Alas, I'm not always right.  But in this case I am.  🙂
Did you give it a go?
Most objects in TestStand inherit from the PropertyObject class.  The PropertyObject class has a property called Name.  In my statement I return the StepType object by using Step.StepType.  Then I use the Name property to get the name of that object.  NOTthe name of the Step.  If I used Step.Name then you would be correct in assuming that the name will change and can be anything.
And ultimately you will most likely be using something like: RunState.Sequence.Main[Some Index or Step Name].StepType.Name.  Or if you are in an engine callback you would use something like: Parameters.Step.StepType.Name.  Or if you are iterating through the sequence in an external code module it would depend on how you are getting the steps.
Hope this helps you understand it a little better.
jigg
CTA, CLA
testeract.com
(4,364 Views)
