05-09-2013 11:47 PM
Hi All,
Can someone help me to setup or config my teststand software for getting details of failed results for both main-seq and sub-sequences.
I can get the report for Limit test result OK if using in main-sequence however if I have all my Limit Tests in sub-sequence then calling it from main-sequence the report only indicated where is FAILED but not actual Test results.
05-10-2013 03:08 PM
Hi NotHon,
Is your subsequence in a new thread? If so, this example should be relevant: https://decibel.ni.com/content/docs/DOC-5059
05-13-2013 09:24 AM
@NotHon wrote:
Hi All,
The default behavior of teststand is to do what you are asking for, so perhaps you have disabled results in the subsequence or have otherwise made changes to the default behavior.
-Doug
05-14-2013 07:46 PM
Hi All,
I already got my problem fixed but don't ask me why and how.
Basically I created a new subsequence and copy all the contents into it and bingo! all the test results are there.
Thanks for your input.
