09-28-2006 09:41 AM
09-28-2006 02:22 PM
I changed your sequencefile slightly and instead of using Locals.MyContainer.ElementNum I used an one outside of your container.(Locals.currentElement).
This worked as expected.
For some strange reason it doesn't want to store in the property of your container.
Regards
Ray Farmer
09-28-2006 02:35 PM
Instead of using your datatype. I created a container with the same structure as your data type (called it Locals.MyContainer2), so my variable is just a container and not an instance of..
Modified the For Each step and the Message step to use MyContainer2.
It works just as your would expect.
Therefore the is a problem if you use a instance of a datatype.
Regards
Ray Farmer
09-29-2006 04:32 AM
