NI TestStand
Find if Step is executed or skipped or Not
Hi
Need to check if a particular step is  executed skipped or  simply the step  has not been under the `Cursor´
on basis of this Info I have a code in  PostUUT to act upon
(4,235 Views)
You can check the Result.Status of the step, the status is "skipped" if it is was skipped.
(4,206 Views)
thanks Haarman,
but the steps are not executed at all
i believe the result status is       ""  empty string
(4,202 Views)
That's correct the result status is empty "" when the step is not executed at all.
(4,199 Views)
