07-11-2014 09:44 AM
Hi
Need to check if a particular step is executed skipped or simply the step has not been under the `Cursor´
on basis of this Info I have a code in PostUUT to act upon
07-14-2014 01:52 AM
You can check the Result.Status of the step, the status is "skipped" if it is was skipped.
07-14-2014 02:57 AM
thanks Haarman,
but the steps are not executed at all
i believe the result status is "" empty string
07-14-2014 03:35 AM
That's correct the result status is empty "" when the step is not executed at all.
