11-04-2004 06:50 AM
11-04-2004 08:46 AM
04-17-2015 12:40 PM
Scott,
I'm curious if this option is available yet in 2012 or 2014? Sure would be handy for troubleshooting performance.
Jeff
04-20-2015 05:55 AM
04-20-2015 08:18 AM - edited 04-20-2015 08:19 AM
I don't think there is a builtin way to get a list of loaded modules (you might want to post a request to the idea exchange), however recent versions of teststand do display a progress dialog if module loading takes more than a few seconds (at least if you disable the sequence analyzer first), and this should show you if a particular module is taking a long time to load. See the TestStand help for "Preload Progress Dialog Box".
Hope this helps,
-Doug
04-22-2015 12:19 AM
Hi Jeff,
currently (TS4 to TS2014) i am doing this with a workaround.
I am using the SequenceFilePostStep- Callback. With that i am able "scan" the executed step
and add if neccessary to a list of used modules.
see also:
Regards
Juergen
04-22-2015 06:56 AM
So let me understand... You are just grabbing a list of modules that were opened but may or may not be currently open. That will help too. Maybe I can store a reference and check the reference to see if that module is still there and close if it is. Thanks for checking into this. 🙂
Jeff
