12-10-2013 10:04 AM - edited 12-10-2013 10:05 AM
At the moment, my result filtering expression is Result.Status != "Done" && Result.Status != "Skipped", so it removes all steps which are only "Done" or "Skipped". With my current filtering expression, any step with the "Done" status will not be displayed in the report even if there are "Additional Results". I would like to improve this by filtering only if there is not result.
This means that I would like to log in the report any step which returns a value including values added in "Additional Results".
Is there any way to achieve this ? I've been looking in the RunState but I was not able to find there the additional results are stored.
Thanks !
Alex
12-10-2013 10:39 AM
You can also check if AdditionalResults is empty or not:
GetNumElements(Result.AdditionalResults) > 0
