02-12-2013 08:15 AM
how can I give an action (LabView adapter) a file as parameter.
I have a VI which needs a path (a text file to parse)
I can change this to string.
a) But how can I give TestStand this file as parameter and
b) when this is possible, is it also possible when the source is a networkshare?
thx
02-12-2013 09:02 AM
The basic way is to use a string in TestStand.
It doesn't matter if it is a network shared file. As long as you can open the file, LabVIEW will be able to do the same.
