02-19-2014 09:39 AM
the deployment Image works fine in dev system.
but in Deployment system "Failed to Load a required Step's associated module Err:-17600" this error.
I suspect it has to do with the search files.
where in deployment machine I can change the the search file settings.
Well i tried a sample (simple)project but it worked on the deployment maschine.
2. I am using classes& objects in my seq file. (I tried to take every precaution to play it safe)
02-20-2014 06:50 AM
A small correction-
The Deployment Image works fine(on Development PC) only if the Path for the Original VIs, Proj. Files, Libraries(Actual Project files) is selected from the "Edit Search Directory"
The Deployed Sequence cannot take its Support VIs & Project file into consideration but searches for the original VIs Proj. Files
eg a) Original file C:\NG
b) Deployment Image C:\Image\Target\NG\
if I Deselect "a)" in Edit search Directories ( Mind It "b)" is selected ) the Deployment Seq & the original Seq both hang Teststand
otherwise if "a)" is selected both work fine
02-20-2014 01:37 PM
aparab,
The Deployment Utility should be changing all of the paths in your sequence file to point to the new location of the VIs and projects as they appear in the deployment. To clarify, if you open the sequence from the deployment image location and execute it with the LabVIEW adapter set to the Run-Time Engine, are you still seeing these errors about the files not being found?
Also, I noticed your other post where you mentioned an error about not being able to locate the LabVIEW project file on the deployment system. It seems like these two issues are related. If you look in the deployment image folder hierarchy, is the LabVIEW project file located there? If not, we might check the Source Files tab of the Deployment Utility to determine whether the project file appears in the list of source files.
02-21-2014 02:47 AM
Hello Daniel,
Thanks for the response!
1. Well I tried with one of the eg VIs from Teststand where I changed the path of the deployment Image (eg I made the deployment on Desktop) and it works fine on both (dev. & dep)
2. " sequence from the deployment image" works fine on the development maschine with LV runtime. with the original Development -Source files.
With the Deployed-Destination Project files Provided I open the LVProj in Labview and save it (There r no changes needed to the LVProj) .
2a as mentioned the Edit search directories also play a role.
02-21-2014 08:18 AM
aparab,
I want to make sure I understand you properly, so let me clarify my understanding on a few of your statements.
1. So if you generate a deployment with a TestStand example instead of your test code, this works properly. Is this correct?
2. After generating a deployment of your test system, you are able to correctly run this sequence from the deployment image on your development machine, is this correct? When you say "with the original development source files", are you saying that the sequence is executing with VIs from the development location on your machine rather than from the deployment image?
Also, are you using relative paths for all LabVIEW projects and VI calls in your test sequences? This can certainly make a difference in the ability to execute your test sequence from a different location on disk.
02-21-2014 08:35 AM
Hi Daniel,
thanks for the response
Ans to ur ?s
1. yes
2. yes the seq work fine with the Original files (as thts the path in the Search directory) also it works fine with the image provided I Select the files in Search and also I have to open the LV Proj in labview and save again.
3. yes I totally use relative paths.
In my deployment system I just have labview 2012 SP1 Runtime as thats also on my dev sys.
if u want I can send u my image file. just for a second look
02-21-2014 09:02 AM
It seems like if I pack the whole project as Labview Packed Library it works on the deployment machine.
06-25-2014 11:52 AM
Hi guys,
well have to reopen the thread
I am making the deployment as a Packed Project Library
if u take a look at the image file well thts "Seq analyzer " from my deployment machine where I dont have Labview Development, only runtime
If I Analyze the same Deployment seq file in my development maschine everything is OK
the issue is only with one vi
could it be that some labview files (inst.lib etc )are missing !!
06-27-2014 10:08 AM
there was a windows DLL missing in my deplyoment maschine "msvcr100d.dll "
NI Support helped me thr this as I didnt have labview on my deployment maschine.
& on Dev maschine all was OK
07-08-2014 12:18 PM
I think the 'D' is for debug, which means you are probably using a dll compiled with debugging. For maximum performance you might want to use release build versions of your dlls on deployed machines instead. That would also get rid of the need to install the debug verison of the visual C runtime on such machines.
-Doug
