Well, that is unfortunate.
The reason we need the process model is that it contains our entire failure handling. I had hoped there is a way to tell TestStand to call another Sequence apart from the MainSequence from the process model. Apparently there is not.
I guess I will have to make a SequenceFile which contains just one SequenceCall that will be altered dynamically or something similar.
So the error I recieved tells me that TestStand could not find the MainSequence. And the SequenceNameParam is actually useless unless you pass a zero reference as ProcessModelParam? An NI-Engineer also contacted me this morning and told me that in a case like in the picture above you would have to pass the ExecutionEntryPoint as SequenceNameParam?
All of this is quite confusing for an example...
Thank you, jigg, for the clarification.
Regards
Tarik Ilhan
