02-17-2010 01:07 PM
02-17-2010 02:11 PM
02-17-2010 02:23 PM
ok, I don't see that tab in TestStand. There is "Step Settings" and then "Output", but Output doesn't have anything to what you're referring to.
02-17-2010 02:27 PM - edited 02-17-2010 02:28 PM
What version of TestStand are you using? I don't know when this was added but in 4.2, the screen looks like the image below.
02-17-2010 02:49 PM
02-17-2010 02:57 PM
I think it was actually introduced with TestStand 4.1. You might have to write a batch file where the output is redirected to a text file. You don't mention what programming language you are using but it might be simpler there.
10-06-2014 03:41 AM
Hello, once you have the ping answer in the Step.StdOutput.Text variable, I would be very interested to know how to analyze the answer 🙂
Is it necessary to use a code module or is it possible only via teststand?
Thank you
10-07-2014 11:10 AM
Hi BRBASTS,
What do you mean, "analyze the answer"? You should be able to do something with the result of Step.StdOutput.Text in TestStand via the use of TestStand API expressions. No code module required.
TestStand 2012 Help: Expressions:
http://zone.ni.com/reference/en-XX/help/370052K-01/tsfundamentals/infotopics/bldgblocks_expressions/
In the future, you'll have better luck getting a response from the community if you create a new forum and add a link to another for reference (if needed). This forum is almost 5 years old.
Thanks!
