NI TestStand
Error while importing a big array with thr property loader
the following problems occure: when I want to import a *.txt file with a array of more than arround 3300 members with the property loader, the following error meassage occures:
property loader step failed to import or export properties
x property values were found
x-1 property values were imported from y rows
Error code: -18, user defined error code.
how can I solve this problem?
I think sizes of arrays are limited somewhere in the source code of the property loader. is it possible to increase this size? And how?
regards samuel
(2,610 Views)
Could you attach an example of your .txt file and your sequence?
(2,593 Views)
