NI TestStand
Error when loading a vi module from teststand sequence but vi executable runs OK
@abelino wrote:
[...] even if not activated, should fix the issue too? [...]
No. You do need at least the LV Base Development license active and the TestStand adapter to execute code in Developement Environment.
The only option to 'fix' this for RTE (regardless of activation) is to create a proper deployment package.
I recommend you to look into the TestStand Deployment Utility as this tool really helps a lot in creating such a package (Image or Installer, just like you configure it).
Norbert
Expert: Geometry
Message 11 of 11
(378 Views)
