NI TestStand
Error occurred when Deploying TS and LabVIEW Runtime Engine only
Hi all,
I am new to Teststand Deployment.
Now I want to deploy a clean installer with Teststand 2012 SP1 Engine, LabVIEW 2012 SP1 Runtime, VISA 5.2 Runtime.
My Sequence file is empty.(In fact with a Label Only):smileytongue:
But I got "Internal error code -12 Making an installer...",and "MSI error code: 110"
Attachment is the Log.
Any Suggestion? Thanks.
czhen
Win 10 & LabVIEW 2014 SP1
(4,552 Views)
Accepted by topic author czhen
Thanks to KateB.
Now i find out why that error happened.
I installed LabVIEW 2012 first, then overwrited with LV 2012 SP1 but no uninstallation.
I think this made Teststand to be comfused or maybe something conflict.
Now, i install LV 2012,or LV 2012 SP1, only. It works fine.
czhen
(4,531 Views)
Hey czhen,
I'm trying to determine why this occurred and see if it's a reproducible issue that we should investigate further. Could you let me know what other NI software you have installed on the machine? Also, you mentioned that you installed LabVIEW 2012 SP1 over 2012--did you use 2012 for a while before upgrading, or was this a fresh install on the machine?
Thanks!
(4,517 Views)
Daniel-E 已写:
Thanks!
Yes,it was a fresh install on the machine. Iupgrade2012SP1 immediatelyafterLabVIEW2012installation.
Then installed Teststand 2012 SP1.
Attachment show installed NI-Products. In addition, I only selected NI-VISA 5.2 in Device Driver disk(DCD-Aug12-1).
czhen
(4,502 Views)
add attachment.
czhen
(4,501 Views)
