11-05-2005 09:15 AM
11-06-2005 10:56 AM
I guess that you do not have a copy of labview 7.x. I would suggest contacting you local NI representive.
Regards
Ray Farmer
11-06-2005 11:10 AM
I had the 30-day trial of 7.1, but it expired. I installed the 30-day trial of 8.0. Is there a way to remedy this and still keep 8.0 installed?
11-07-2005 12:53 AM
You could un-install your 7.1 trial software and try install it again it shouldn't affect the version 8.0 install.
Regards
Ray Farmer
11-07-2005 11:33 AM
Mrbean,
Have you tried to mass-compile the VI's used by the exercises?
If you mass compile the VI's using LV8 you will convert all the VIs to LabVIEW 8 Version.
I recommend you to make a copy of your VIs before mass-compiling them, so you can still work with the original VIs using a previous version of LabVIEW.
Hope it helps.
11-07-2005 12:12 PM
11-08-2005 01:13 AM
Even if you mass compile, you will still end up with the same error!
Regards
Ray Farmer
11-08-2005 06:02 AM
Ray,
Why would I still see the same error?
11-08-2005 07:15 AM
When you load the VI(s) you affective compile those VI's, if you cannot achieve this at load time then you are not going to achieve using the Mass Compile command.
What you need to do is bring them up to an intermediate version.
I think your VIs must be version 5.x
Regards
Ray Farmer
11-08-2005 02:29 PM
Go to Configure >> Adapters. Select LabVIEW and press Configure. In the first group, which option do you have selected? If it is LabVIEW Run-Time Engine 8.0, I would expect this problem. If you select Development System, it should work properly. I did this on my machine and it worked fine.
Allen P.
NI
