05-29-2008 05:00 AM
Solved! Go to Solution.
05-30-2008 04:10 PM
06-09-2008 11:53 PM
Nestor G
Thank you for your replay.
I developed the code in 8.2.1 and the code is running in the same 'Lab VIEW 8.2.1' very well. The same code can open in Lab VIEW 8.5 (not 8.5.1) with out broken arrow and, while running the code only it shows the error dialog 'two copies of application manager control in the same vi' but actualy there is only one 'TS UI application manager control' in the vi.
FYI, Bellow vi runs without error in labview 8.5
C:\Program Files\National Instruments\TestStand 4.0\UserInterfaces\NI\Full-Featured\LabVIEW\Load Top-Level VI.vi
Please help me to fix this bug!
Thank you,
Yogesh
06-11-2008 04:41 PM
Yogesh,
Would you please attempt to mass compile your OI.
Simply navigate to Tools > Advanced > Mass Compile in LabVIEW and select the directory containing your OI VIs.
- Do you get any warnings or errors from the mass compilation?
- Save the top level VI and run the OI again. What is the behavior?
- Would you be interested in sharing your custom OI? If so, please post your e-mail address and I will reply with a NI Support E-mail.
Thanks Yogesh...this is indeed a weird one!
06-20-2008 03:55 AM
Hi Nestor, I'm having the same problem that is discussed here but did you find a solution for this problem?
Thanx
06-20-2008 08:49 AM
Hi All,
I found a solution.
Error is because of two or more 'Test Stand Application Manager control' placed in the same vi hierarchy (also sub vi).
You can rectify this by changing all 'Application Manager control' in to 'Application Manager control-Refnum' (avilable in refnum sub palatte) except main one.
FYI
This error will pop up only in LV 8.5 not in LV 8.2 (Don't know why like this!)
Thank you Nestor G and all
Yogesh
08-15-2013 01:58 AM
Thanks a lot.
the same bug when using LabVIEW 2012 to execute code developed in 2011.
