02-17-2006 04:36 PM
02-17-2006 04:54 PM
02-17-2006 05:01 PM
Allen,
I get the error after deploying to new PC. I get the error as soon as I select " Test UUT's". I do not get the error on the development PC.
02-19-2006 11:51 AM
Have you got the ProcessModel sequence file "SequentialModel.seq" on you Deployed system.
You should find it in "TestStand\Components\NI\Models\TestStandModels" folder or "TestStand\Components\User\Models\TestStandModels" folder.
Regards
Ray Farmer
02-20-2006 08:57 AM
02-20-2006 10:22 AM
Do you know where the step is failing? The error sounds like you are trying to reference a variable that does not exist. Since it is only happening on deployment, you probably are referring to a Station Global variable that has not been deployed. Try setting breakpoints in your model and step through the code to see where it fails.
Allen P.
NI
