06-03-2010 09:09 AM
TestStand 4.2.1 issue whenever I chose to execute Selected Steps I receive this error. After receiving this error once, every action in TestStand generates this error popup. Sequences still appear to run but this is very frustrating.
I there some setting missing that is causing this error to appear. These sequences ran just fine in TestStand 3.5.
06-03-2010 09:29 AM
Is this using the SeqEditor?
regards
Ray Farmer
06-03-2010 09:40 AM
06-04-2010 04:37 PM - edited 06-04-2010 04:39 PM
Hi mvterry,
I have a few clarification questions for you:
Cheers,
Michael W
06-07-2010 12:46 AM
06-07-2010 07:36 AM
1, I am strictly using the developer interface in the seq editor. We have no use for the Operator Interface as the test engineers who write the sequences are the only ones who execute them.
2. We utilize the Report Generator Toolkit from LabView. It seems as though using the interfaces we designed with this interface causes the issue. When we upgraded to 4.2.1 from 3.5, I think the IT group forgot to re-register the .dlls we were using with the toolkit. I have went ahead and did that and have not experienced the problem again...yet. I haven't executed any sequences with the report generator toolkit either so I am not ready to call it a solution. Will attempt to execute one again today.
3. Once the issue occurs, the error returns for every mouse click, tab, or keystroke performed within TestStand. It is necessary to close and restart TestStand to get rid of the error once it appears.
Thanks for your response and I hope that I have fixed my own problem. Will repost if this is not the case.
06-07-2010 07:37 AM
Once I experience the problem again, I will repost the screen shot. My apologies for not doing this in my original post.
Thanks for your help.
09-09-2011 12:15 PM - edited 09-09-2011 12:16 PM
I am having a similar problem. When I try and launch test stand I get this error.
09-10-2011 10:10 AM
Go to the directory:
<User Directory>\Local Settings\Application Data\National Instruments\TestStand <version\
And delete the file layout_current.bin.
Then try starting the sequence editor.
Hope this helps,
-Doug
